oppy
Sequential Part Numbers
When using OCL to generate a cut list, is there an option to instruct OCL to assign sequential part numbers (or letters) to each component within a model?
Regards,
Ryan
Martin Müller
I am not sure I understand your question. Could you please give us an example?
Does it bother you that the numbering is restarting within each group?
oppy
Hello Martin,
Thanks for replying.
Yes, I would like the part numbers to continue across groups. I admin it is a trivial desire but when I export the part list and print labels (of my own design) I would prefer that each label has a unique part number associated with that component.
Thanks,
Ryan
Martin Müller
Hi Ryan,
Yes, you can have a sequential numbering by selecting it in the Options. Parts will then be numbered throughout the project.
You can even save the parts number, so that adding a part will not overwrite the existing parts. The newly added part will get the next available label (number or letter) that has not be saved.
oppy
Hello Martin,
Apologies. I overlooked this option!
Regards,
Ryan
oppy
Merci Martin Müller !
Regards,
Ryan
137 vues
Autres questions de oppy
