josworkingwithwood
Which saw is best: a miter saw or a radial arm saw?
Hello everyone,
I work on various woodworking projects, such as outdoor kitchens and garden furniture. Currently, I’m using a Holzzman miter saw, but it’s not precise enough. I’m planning to build a workbench with a fence and saw stops and am looking for a new saw that will work well with this setup.
I’m torn between a radial arm saw and a miter saw:
For the miter saw, I’ve looked at the Bosch GCM 12 GDL Professional and the Makita LS1219L.
For the radial arm saw, I’m considering a second-hand model from DeWalt.
I don’t need to cut angles very often, but occasionally I need to make very sharp angles. I also want to know if a radial arm saw is useful for making joints by tilting the saw or for crosscutting.
My questions are:
  • Is a radial arm saw precise and easy to work with?
  • Which of the two works better with a fence for saw stops?
  • Is a radial arm saw safe to use?
  • Is it optimal for making joints or cutting in length with a radial arm saw?
  • What is better?
  • Do you have any other recommendations for a saw that works on 220/230V?
If you have better suggestions they are also welcome!
Thanks in advance for your help!
josworkingwithwood
Thank you all for the very detailed, valuable and fast responses. I really appreciate it!! I am a young woodworker (20) and sell various projects in my spare time. I am considering turning my hobby into a full-fledged business after or even during my studies. I was born and live in the Netherlands 😉, but I am currently spending 6 months in Canada for an internship at a company that builds log cabins. I have only been on this platform for a week and I am already impressed by the helpful community here!!
About my original question: I want to convert the saw into a long, fixed workbench with a guide and a length stop. How does this work then in combination with the guide of a radial arm saw?
(the radial arm saw is 220/230 volts, second hand)
josworkingwithwood
Hello;
A miter saw will be less heavy, with finer blades and lower diameter (therefore less possibility of vibration). Negative toothing blades are possible to limit bursts. But it will be limited, due to its power and its decline to the most fable sections of wood. In return, it will make more thin and more precise cuts.
A radial saw like Dewalt in photo, will be more powerful, but often (always ?) In 380V. They are heavier, and more difficult to maneuver and settle. These saws are generally designed to cut sets or strong solid wood sections. (In French: TRONCONNER = crossing across, perpendicular to the wood wire. As opposed to DELIGNER = cut in length, in the direction of the wood wire).
In some cases, it is a means of making cuts on large widths (for the manufacture of stairs, for example).
They can be adjusted in orientation, as in inclination. Or length cuts with guide and stop.
But for all these operations, it will be less precise than a tab saw.
Regarding safety, the miter saw are equipped with fairly effective protectors. You must be maneuvering by backing up the blade in the high position, then lowering it and advancing towards the guide (EN OPPOSITION, in French).
On the other hand, a radial saw will cut by backing up in wood (EN AVALANT, in French), often of high section of wood. Specific blades are therefore necessary to limit the risk of kick back, but they remain more dangerous than miter saws.
The cutting of wood in the direction of the wire is possible, but must only be made in opposition, in this case. But it must remain a troubleshooting solution, and punctual, because it is clearly not the safest solution.
Hoping to have helped you a little, knowing that my English for the technical terms in very low ... and for the rest, just correct.😆
EDIT. Without being sure, I found this ⬇
I disagree with part of your answer. Miter saws are way less precise than radial arm saw for 2 main reasons :
  • settings on a radial saw are on différent places so each settings is a lot more rigid (almost every miter saw is less precise when they are in full extension even big premium brand like Festool)
  • radial arm saw are stationary tools everything is more rigid while miter saw have been invented as job site saw. It is like comparing a big shop saw like panel saws and little contractors saw like Dewalt or Bosch précision is way different.
Pour en avoir utilisé en tant que professionnel depuis largement plus de 40 ans, les scies radiales sont certes, de construction plus robuste, mais parce que d'abord destinées à des travaux lourds, de tronçonnage de massif principalement. (D'où le fait que les tables et les guides sont souvent très abîmés, sur celles qu'on trouve dans les ateliers).
Les lames qui les équipent sont prévues pour ces gros tronçonnages, et on trouve peu de lames fines aux dentures adaptées pour des travaux fins. Ces lames sont plus sujettes aux vibrations, du fait de leur grand diamètre.
Les pertes de précision, sont proportionnelles à la longueur du bras ou du développement, sur les deux types de scies. On en a donc également sur les grosses scies radiales.
Concernant les scies dites à onglet, elles existaient bien avant que ne se généralisent les scies que tu appelles "de chantier" dont tout le monde s'est équipé aujourd'hui, y compris amateurs. Elles étaient la plupart du temps stationnaires et de construction plus lourde que celles que l'on connait aujourd'hui.
Si on s'entend bien sur le terme de "précision", il est difficile d'obtenir des coupes d'onglets aussi précises et propres pour des petites moulures, de cadre, des pare-closes, par exemple sur une radiale qu'avec une scie à onglet (à condition que celle-ci soit de qualité correcte, bien sûr).
Medalegno je pense que la question est posée pour des machines actuelles. Actuellement les scies à onglets sont pas ouf en précision même la Kapex à des soucis et aujourd'hui elles sont plus destinées à être utilisées avec les stand mobiles disponibles dans la plupart des catalogues qu'en atelier (même si ça reste courant je te l'accorde) .
Pour les lames c'est pareil les scies radiales sont très courantes aux états Unis et les lames disponibles n'ont rien à envier aux autres bonnes lames, si la personne qui pose la question est aux Usa elle pourra avoir accès à toutes ces lames et même plus puisqu'il existe maintenant des fraises à plaquettes et des "dado stack" qui se montent dessus.
Après effectivement pour des moulures ou de petits profilés c'est pas l'outil le mieux adapté mais pour des applications spécifiques il existe des scies spécifiques (d'ailleurs pour les moulures Festool à une scie spécifique sans déplacement radial)
Erebor Il pose sa question à des français, sur un site français... Je réponds donc pour ce qui nous concerne. (d'ailleurs, si sa question est en anglais, je ne vois rien qui me dise qu'il soit américain).
J'ai eu bien assez à faire à connaître le mieux possible le matériel auquel nous avons accès ici, et à savoir comment l'utiliser au mieux. 😉
Maintenant, quand on fait un tour dans un atelier pro, il sera courant de voir une ou des scies à onglet à proximité des zones de montage, pour toutes les coupes de finitions... Et la (grosse) radiale dans une zone de l'atelier réservé au débit massif, quand pas recouverte de sciure ou de chutes !
On peut d'ailleurs constater, dans la même idée, que beaucoup des scies radiales lourdes proposées sur LBC, ont très souvent des guides et tables très dégradés, signes qu'elles ont surtout servi à des gros travaux de débit et de tronçonnage de plateaux massif. 😆
Ça n'est sans doute pas par hasard.
Pour autant, ces grosses radiales peuvent effectivement servir à des coupes précises, avec des tables et guides en parfait état, dans ce cas. Mais dans ces usages, c'est essentiellement pour des coupes pour de la menuiserie, pour ne pas dire "grosse menuiserie", ou des escaliers, par exemple.
Bref, nous parlons de deux catégories de machines très différentes, chacune adaptée à un ou des usages précis, et offrant une précision adaptée à ces différents usages. Mais ces usages ne sont vraiment pas les mêmes, ni comparables.
À propos des machines actuelles, je répondais à ton affirmation sur le fait que les scies à onglets avaient été "inventées comme scies de chantier".
Mais elles existaient bien avant, en scies stationnaires d'atelier. Même s'il est exact que les scies à onglets actuelles, plus légères et mobiles, les ont souvent remplacées en atelier, aujourd'hui. Toujours du fait de cette légèreté, l'usage en chantier est également apparu assez récemment avec ces nouvelles machines plus faciles à déplacer.
Les scies radiales plus légères qu'on connait actuellement, ayant de plus la possibilité d'être inclinées, en plus d'être orientées, ce que n'avaient pas les anciennes scies à onglets stationnaires.
Radial arms can be more precise than miters (less joints, surdier rails...) but requires more laborious setting up. It's not as fast as a miter when you want to change angles very often, but more precise when doing multiple identical pieces.
2 :
BUilding a workbench for a miter is a pain in the a** : several levels, right orientation and tight fixation of the tool... and if you change your saw, you must change the bench.
With a radial arm you just have to take a piece of plywood, make a cut to get a reference and place your fence... easy !
3 : any tool is as safe as you make it. As long as you use it for cross cutting with the right blade (negative rake saw blade) and with push sticks and clamps when required you're good.
4 : rip cutting is possible with a radial arm, but it becomes potentially dangerous : there's no ripping knife, the cut is not supported (the blade wants to pull the wood upward), setting the width is not easy...
For making joints, once you're set it's more precise than a miter...
5 :
Radial arm saw is more precise, can cut wider boards, and can do things you can't do with a miter ; it will probably last a lifetime. But it is not as easy to set and needs a huge space.
Miter saw is lighter, easy to use and fast to set, takes less space in the shop. But it's not very precise ; and probably won't last very long.
1 574 vues
