oppyoppy
Are there any plans to add a cutting diagram for solid wood?
I don't see the ability to generate a cutting diagram for hardwood and as a result, have to define my hardwood as sheet goods (so I can generate a cutting diagram).
EstOuest
No there is not. your solution is the right one.
As there are no two identical wooden boards and in addition there are often faults to be avoided in each one, it seems impossible to come up with a good solution.
146 vues
